Heat & Beat Specialist
Got everything wired and started testing the electrical system last nite. Got a lot of wire tracing to do, as most things don't work exactly right. One thing I absolutely could not figure out was how to wire a hazard switch into this mess. We are using the American Autowire harness, and there's a provision for a hazard flasher feed on the big 4" TS connector. I just can't figure out what to connect it to. Has anybody else done this?
FFCobra Captain
This diagram helped me a lot. Turn Signals & Hazard wiring was the most confusing part of the wiring for me...print this out and sit in the car with it. It helps.
FFCobra Captain
Sure looks small. Right Click and 'save as' on your desktop and you can enlarge it, or go to www.my427sc.com and look at a larger copy there. It's in the build section under Lights.
Here it is big. With the AA harness, where is the "brown hazard flasher #951" equivalent from the Painless harness??
Super Moderator
John, on the painless fuse block, there is a Hazard Flasher included - in the pic below, it is the circle at the lower right. I would think your fuse block would have something similar?
