Well Grasshopper...I've steered with my knees, held a Coke can in my left while holding (sensored) in my right...trying to releive myself while doing 75 mph on the expressway. Is that a speed bladder???? dino
I've used "speed bleeders", vacuum pumps, and used beer as bait to get help. My favorite method is to run a long plastic tube from the appropriate bleed screw to the master cylinder. Then I can sit in the car, with a beer, and pump the pedal. Life is good.
Though I really like oldguy's method I have Russel speed bleeders on the front I could not get them to fit right on my Tbird rears I've checked the numbers and gotten a new set still dont fit. probably my calipers. So I default to promising my 9 year old daughter a good smokey burnout if she helps. For initial bleeding the speed bleeders are not that good but seem to work fine for fluid changes once you get all the air out of the system.
I don't get it... last time i blead breaks.... and left the master cyl top off I got fluid allllllll over... so how in the world can you run the plastic tubing to the resiviour? Without replacing the top! So confused!
