1 - 14 of 14 Posts
Has anybody put together a Torque Spec Sheet yet?
I think it would sure be handy to have that. If no one has started one I am starting one right now.
Any suggestions for changes through experience Etc. is greatly appreciated. Some torque specs I can not find in the manual but I am sure someone here knows them. So please add as many as you can.
Thanks!!!!!
Here is what I have so far from the FFR manual and added inserts from FFR.
************** IRS *******************
Rear IRS axle nut 250 ft-lbs.
Rear shock upper and lower 1/2" -13 bolts 70 ft-lbs.
Rear IRS 5/8" -11 bolts 85 ft-lbs.
Spindle attachment bolts 100 ft-lbs.
Drive Shaft to center section bolts 70-95 ft-lbs.
********** END IRS Section ******************
********** IFS ******************************
IFS bracket Upper A-arm assembly to spindle 140-200 ft-lbs.
Lower ball joint 80-120 ft-lbs.
Upper ball joint ??????.
Adjustable upper a arm bolts 60 ft-lbs. "Be careful there is a known "safety issue" with these bolts call FFR if you have the old bolts and get new ones"
Upper a arm bolts to slotted mount plate 100-120 ft-lbs.
Front shock upper and lower 1/2" -13 bolts 70 ft-lbs.
Lower control arm bolts 110-150 ft-lbs.
******** End IFS Section ************************
Discussion Starter · #2 ·
I found another one.
Verticle shock bolts 27 ft-lbs.
Okay I found some more but I see the last one I posted is contradictory to this new one I found for the verticle shock.
Verticle shock to axle bracket 45-60 ft-lbs.
Upper control arm to axle 70-100 ft-lbs.
Upper control arm to frame 80-105 ft-lbs.
Lower control arm to axle 70-100 ft-lbs.
Lower control arm to frame 80-105 ft-lbs.
Quadshock bracket to frame 56-70 ft-lbs.
Quadshock to bracket 56-70 ft-lbs.
Quadshock to axle 56-70 ft-lbs.
MatTheHat
Do you know the torque spec on the upper ball joint? I could not find that in my old Mark I manual.
What is the torque spec on the castle nuts for the upper and lower ball joints?
Discussion Starter · #11 ·
Yes that upper ball joint is a very tight fit. My socket barely fits. Thanks for the info I will torque that bolt down tonight.
Discussion Starter · #12 ·
I noticed in another post that people were marking the bolts and nuts after they have been torqued down with nail polish, sharpie markers, or paint markers. A line on the nut and on the frame of the car will let you know if your bolt or nut is slipping. It is also a good indication that you have torqued the bolt or nut down so you do not miss any.
1 - 14 of 14 Posts
