1 - 10 of 10 Posts
My hallibrand wheel appears to be rubbing the top of the parking brake bracket. Can this be?
Need more info.
What size wheels?
What rear wilwood brake kit?
I'm guessing there 15"
If it's the FF Wilwood 12.19" kit it doesn't fit 15" wheels. :eek:
From FF website.
"This brake package has been custom made to specifically fit inside the 17” FFR Halibrand Style wheels on the 79-93 width axle."
Can you show pictures?
Apparently when I attach the other end of the cable, there will be enough tension to pull the bracket slightly away from the wheel. Thanks for the replies. I'm enjoying the process!
Was the FF e brake cable long enough for you? I'm finding that I'm about 1 cm short. I've lowered the e brake handle and unwound that clevis to the very end. All I can think of is maybe have someone push down on the caliper's e brake lever while I pull the cable.... But I think I must be missing something...
Just found out there's been a "revision" at Factory Five on this and they're sending out a spacer on the e-brake handle assembly's clevis that should allow the cables to reach.
1 - 10 of 10 Posts
