1 - 20 of 27 Posts
Broken-down. Sounded like ticking then knocking maybe backfire some said. Engine never felt rough. Spiked in temp a little then back down all in a minute. When I started in the garage I heard it's squeaking like it was a bad belt.
I shut it down and had it towed back.
Crusing the internet people mention the pulley system and the belt well I went to go check the belt and I'm missing two bolts and one of them loose on the main pulley that's connected to the crank.
yikes! I'm going to be super paranoid looking for loose bolts for a while.
  • Like
Reactions: jhargrove
Discussion Starter #3
Well I doubt that would cause the break down but it's definitely an issue
Buy a $2 paint stick and mark EVERY bolt/nut as soon as you torque it. It is easy to miss one. Also a quick visual reference two years from now when you are looking the car over to see if one has loosened.
Krusty
Discussion Starter #7
Did it actually stop running or just begin making noise due to the loose pulley?
It did die once in traffic I started it right back up to get it to safety. Made a bunch of noise and I shut it down.
Discussion Starter #8
Krusty
I did this often. Especially on the torque Spec bolts. Apearantly not enough.
There is no shame in it. A little counseling is ok too. Been there a few weeks ago.
  • Like
Super Moderator
Damn! Going to check mine
Years ago, 10?, 15? I found my crank bolts loose on an inspection.
In 1968, I sold a perfectly good Austin Healy Bug Eye Sprite because of a noise up front.
Guess what it was...............?
  • Like
Discussion Starter #13
Crazy. I hope it's only the pulley
My 1990 efi set up had similar symptom in the driveway. Ended up being an issue with the ignition module on the side of the distributer . Now I keep a spare just in case.
Those TFI modules are a known problem.
Always carry a spare and the little socket to change it.
I am thinking two separate issues. The loose bolts were making the noise, but engine should still run. The backfire and stall sounds to me like a distributor/eci issue.
When I had my issue, I purchased what I thought would be an upgrade (I think it was a Mallory) , had to return two as defective and then rebuilt my original and found a OEM Ford Ignition module and been perfect since.
1 - 20 of 27 Posts
