Did you have to increase the length of the clutch cable?? cuz mine is always in a disengaging mode. Do you think it needs adjustment or needs a longer cable?
Thank you
Did you use the '94/'95 bellhousing? This bell is deeper/longer due to the relocated engine placement on these two years. This will possibly require a longer cable to reach the fork.
Hopefully some '94/'95 donor users will chime in for sure...
HTH...
The cable needs adjustment at the top end.
Length should not be the issue in this case as long as the is a bit if slack in the cable somewhere.
Did you add the adjustable quadrant?
how bout some pics of the upper and lower mounting, maybe theres something we can see that may be your problem,
charlie
