1 - 1 of 1 Posts
I collected parts for GTM completion with no donor. I have the following available for sale as one lot only.
Most parts were sourced from Shaun Carter/SMC several years ago, are still as-new, and are boxed with exception of suspension pieces which are assembled for each corner (upper CA, lower CA, knuckle/hub/bearing/balljoints).
Inventory (subject to verification, this stuff has been moved a couple times):
* Front Suspension Kit, 1997-2004 C5 Corvette, contains: (2) Upper Control Arms, (2) Lower Control Arms, (2) Knuckles, (2) Bearing/Hub Assy., (2) Hub Backing Plates, Hub Mounting Bolts, Ball Joint Nuts. Upper & lower Control Arm Bolts & Nuts, Lower Shock Mounting Bolts & Nuts, NEW
* Rear Suspension Kit, 1997-2004 C5 Corvette. Contains: (2) Upper Control Arms, (2) Lower Control Arms, (2) Knuckles, (2) Bearing/Hub Assy., (2) parking Brake Assy., (2) Hub Backing Plates, Hub Mounting Bolts, Ball Joint Nuts. Upper & lower Control Arm Bolts &Nuts, Rear Link Assemblies with Adjustable Tire Rod Ends & Nuts (Pair) NEW Joint, Outer Axle with boot, clamps and grease, 1997-2004 C5 Corvette, NEW GM Nut, Rear Axle Shaft 1997-2004 C5 Corvette NEW GM
* E Brake/Parking Brake Handle Assembly With Front Cable, 2005-2009 C6 Corvette NEW GM
* Bracket, E Brake Cable to Body, Front (1 req) NEW GM
* Cable, Rear E brake RH Side, 1997-2004 C5 Corvette, NEW
* Cable, Rear E brake LH Side, 1997-2004 C5 Corvette, NEW
* Switch, Brake, 1997-2004 C5 Corvette, NEW GM
* Connector with pigtail, Brake Depress Switch, 1997-2004 C5 Corvette, NEW GM
* Bracket, Brake Switch, 1997-2004 C5 Corvette,
* Horn Connection with Spring, to slip ring C5 Corvette NEW GM
* Vehicle Speed Sensor (VSS) NEW GM
* Latch, Hood LH, 1997-2004 C5 Corvette, New GM
* Latch, Hood RH, 1997-2004 C5 Corvette, NEW GM
* Striker, Hood Latch, 1997-2004 C5 Corvette, NEW GM Qty 2
* Cable assembly with handle, Hood Release, 1997-2004 C5 Corvette, NEW GM
* Hinge, Hood RH, 1997-2004 C5 Corvette NEW GM
* Hinge, Hood LH, 1997-2004 C5 Corvette NEW GM
* Reservoir, Coolant, 1997-2004 C5 Corvette, no sensor NEW GM
* Cap, Coolant Reservoir, 1997-2004 C5 Corvette NEW GM
* Wiper Motor, 1997-2004 C5 Corvette With Crank Arm Remanufactured
* OEM Connector with Pigtail, Wiper Motor, 1997-2004 C5 Corvette NEW
* Handle, Outside LH with gasket & mounting nuts, 1997-2004 C5 Corvette, New GM
* Lock Cylinder, LH Door with 2 keys. 1997-2004 C5 Corvette (coded)
* Passenger Door Handle With Key Lock. (Keyed to match drivers door),
* GM 2 wire Regulator, Window with motor RH, 1997-2004 C5 Corvette, NEW GM
* Connector (2nd design) with Pigtail, Window Regulator/Motor, 1997-2004 C5 Corvette
* Regulator, Window with motor LH, 1997-2004 C5 Corvette, NEW GM
* Connector ( for 1st design) with Pigtail, Window Regulator/Motor, 1997-2004 C5 Corvette
* Seat belt Kit, set of 2, (Black) Hardtop, 2001-2004 C5 Corvette NEW GM
* Mirror, LH Door, 2005-2009 C6 Corvette with door gasket and mounting nuts, NEW GM
* Mirror, RH Door, 2005-2009 C6 Corvette with door gasket and mounting nuts, NEW GM
* Horn, 1 of 2, 1997-2004 C5 Corvette, Service Kit, NEW GM
* Horn 2 of 2 1997-2004 C5 Corvette, Service Kit, NEW GM
* Connector with pigtail, Horns, 1997-2004 C5 Corvette, NEW GM
* Lamp, License plate with mounting screws (2 req.) 1997-2004 C5 Corvette, NEW GM
* Socket with pigtail & bulb, License plate Lamp, 1997-2004 C5 Corvette
* Corvette C6 Z06 Brake Package Complete
* C6 Z06 Replacement Rotors Front/Rear New GM
* C6 Z06 Red Calipers Front/Rear w/ HP pads New GM
* Caliper Mount Bolts Front/Rear New GM
* Stainless Steel Teflon Brake Hose Kit Front/Rear Aftermarket
I don't have a radiator, steering column, and any of the engine/ECM/harness pieces from a C5 donor. This a collection of new parts that I wanted for safety, reliability, and no-donor appearance.
Price $9500 for all. The value is all there based on what I paid and some increases in things like the control arms.
I will palletize and prepare for shipment fob Colorado Springs, CO.
I will also deliver at no cost within greater Denver - Colorado Springs area.
PM me with interest or questions. I will try to get back to you promptly.
1 - 1 of 1 Posts
