GTM Brakes
304 Views 3 Replies 4 Participants Last post by  Gordon Levy
GTM
Hello ! I have Wilwood 3/4 260-3374 brake cylinders, they are the ones that came with me when I bought the GTM set. Are the brakes good enough with them? Or do you drive with a brake booster?
I dont have a good answer. I am still building my car.
I have not seen/heard of anybody running a booster, so I would assume that setup is good for the stock C5/C6 calipers.
I went a different route and upgraded to Cadillac ATS Brembo 4 pot calipers with Corvette C6 Z06 rotors all the way around. This is sort of a bolt on setup. The calipers and rotors are a direct bolt on. I kicked my Master Cylender up from the 3/4 to 7/8. Did this because of the increased caliper volume, with the 3.4 in MC's the pedal was a little long.
If your pads are soft and street biased it's going to feel pretty normal. If they are hard pads for track that need temp, first part of a drive can require harder push on the pedal. For significant brake performance, use the AP Racing Corvette Radi-cal brake package. PM for sizes front/rear for GTM as it's not exactly like a GTM.
Also, for anyone building a GTM today, in 2023, make the minor effort to install Teves Mk60 ABS. All it needs is 12V power, ZR1 hubs and you have amazing ABS.
  • Like
Reactions: 1
The Corvette brakes are PBR's similar to the Cobra brake setups and they work OK with decent pads. Like the roadsters I really can not recommend a booster in the brakes because of the lightweight of the cars. My Wilwood kits are a big step up in braking and a designed to be a performance manual system.
  • Like
Reactions: 1
