Hi,
I have a 2009 GTM I just purchased. My problem is my driveway is to steep for the front lip spoiler. I need to raise the height in order to clear.
How do I adjust the coilovers on this car? Thanks for the help
Billy
There really isn't a specific amount of turns as there is a lever ratio along with possibly varying spring rates, so it will not be a one to one thing. You would probably get close by marking the collar position and then moving it down 1", but if you getto where you are putting preload on the spring, then that will change things also. What it comes down to is that it is usually an adjust and check type of thing.
