1 - 16 of 16 Posts
FFR Craftsman
I have an appointment to see Apex Motorsports on Wed. morning (just after 9:00AM). I have no clue what I'll make. Any guesses? Here's my engine specs:
http://home.comcast.net/~289fia_cobra/engine_spec.htm
Note: rear end diff. is 3.55:1
Carburator was swapped to a Speed Demon 650 DP
just over 825 miles on the odo.
[ February 21, 2007, 04:22 PM: Message edited by: 289FIA_Cobra ]
I'll go to 380 @ the wheels once she is tuned. Good Luck! Eric
Similar to mine and I am making 386 at the wheels and I have only revved to 5800 so far because I needed to replace valve springs.
So I'll say 395 rwhp
387rwhp--Good luck!
Living Large
325 at the wheels.
Good luck!
Trent
high many rpms are you planning on spinning it?
FFR Craftsman
Discussion Starter · #10 ·
I just got back to from Apex. This took quite a bit of time to finish but it's done.
The first two pulls were pretty good:
#1: Max Power = 354.08, Max. Torque = 370.82
#2: Max Power = 355.97, Max. Torque = 385.25
The next two are odd balls. We could not get a good/consistent singal from the #1 plug:
#3: Max Power = 289.97, Max. Torque = 359.53
#4: Max Power = 297.19, Max. Torque = 364.38
The last pull was in essence, the 3rd paid pull:
#5 Max Power = 351.86, Max. Torque = 378.38
If you average out #1, 2 & 5 I come up with an average of:
HP: 353.87, Torque: 378.15 ft-lbs.
For just torque across all 5 runs, I get:
Torque: 371.672 ft-lbs.
If we toss out the highest and lowest torque readings, I get: 371.19 ft-lbs.
The printouts are terrible. This is a Dnynojet butthe Winpep7 software didn't give a graph I really preferred. I'll scan and post it later.
The colunmar numbers were missing on all runs but the 2nd and it was even missing RPM readings from 4500-6000 (my rev limit).
In a nutshell, I can say the torque curve was near flat after 3,000RPM through 5,2000, with peak appearing to be around 5200 before tapering down. It's a nice shallow arc. HP was a very linear climb to about 5400RPM.
A/F was averaging what appears to be about 13.4:1 (guessing based on what little info I got from the columns.)
Overall, this is what I was expecting at the wheels.
On another note, if you use a cosnervative (average???) 15% drivetrain loss, this calculates to 444.7 ft-lbs. of torque at the engine. This was more than what I was expecting but again, 15% is just a number. I don't know the "actual" drive train loss.
These numbers are strickly baseline and when Rod and company finally do the exhaust comparo, I can then guess on how this will affect my HP.
PS: I do have a video too. What was funny was on the first run, the moment the guy floors it, the AF probe comes shooting out!
Here's the video link:
http://www.youtube.com/watch?v=YAe5ji6kyRk
[ February 21, 2007, 04:23 PM: Message edited by: 289FIA_Cobra ]
Sounds great! So, there weren't any adjustments made?
FFR Craftsman
Discussion Starter · #13 ·
Nope. This was tuned by a very good carb tuner; he used a high quality OPX(?) IR A/F computer. He set it to a 13.5:1 A/F across the entire power band.
Which reminds me, I need to email him to let him know the results.
Former Roadster Owner
Glad it all worked out well. Thanks for sharing.
-Dan
1 - 16 of 16 Posts
