For those of you that made your Girling reservoirs, how did you drill the hole for the fittings? I can't get it drilled without the leaving sharp edges that I can't smooth and deburr. I'm worried I won't be able to get a good seal with the washers and fittings.
Joey
I used a stepper bit on a lathe. But I think a stepper bit on a drill press would work too. Just used a simple deburring tool to clean it up a little.
Super Moderator
I drilled mine with a step bit and drilled slowly. No problems to date
Stepped bit and careful deburring here also.
427 S/C, Alum Side-Oiler, TKO600, IRS, Pin Drive
My Girlings came with an AN fitting so all good.
