1 - 2 of 2 Posts
Anybody have any photos/posts regarding the rear and side body mounts on a Gen-2 you can share? Trying to determine the best place to start here... Thanks
Greg,
For the side mounts make sure the body it sitting on the sills correctly. Then the holes need to be drilled where the mounting points are on the frame. That was a little feel and point procedure for me.
The rear gets held on by the tail lights. Drill through the body and the steel plate with a hole saw then put the light buckets in and drill the smaller holes for the mounting screws.
HTH,
1 - 2 of 2 Posts
