1 - 15 of 15 Posts
I remember a thread on this subject where "Sealing Washers" were used on the bulkhead connectors that make up the crossover hose at the bottom of the gas tanks. I can't find those washers anywhere local. They're 1" I.D., rubber with a metal O.D. and look like large oil pan drain washers.
Does anybody know where I can order these?
You should be able to find a suitable replacement at any auto parts store.
As long as you find something with similar dimensions, it will be fine.
I would also encourage you to seal the threads with a fuel safe epoxy on
the inner, and outer side of the fitting.
I have these on my car, They work great and no leaks at all after install. Shane a VRaptor Speedworks sells these.
· Premium Member
Hi,
I sell these sealing washers. How many do you need?
McMaster Carr 93783A051 Pressure-Sealing Washer for Screws & Bolts 1" Screw Size, 1.76" OD, .05"-.07" Thk
No leaks
If you have access to a lathe, just cut some groves in the AN fittings that FF supplied and install O-rings. No need for any glue/sealant and easy to install.:001_smile:
Robert GTM 407
Robert GTM 407
Pictures?
How were you able to have a tolerance that allowed the fitting to be inserted into the tank without disturbing the o-ring yet will not leak?
If a 1" hole is made the fitting has to cut threads to be inserted. What size hole did you use?
Here's a pic of the nut still in my lathe. It's really only the o-ring on the outside of the tank that matters since fuel will always migrate past the threads...
1 - 15 of 15 Posts
