1 - 3 of 3 Posts
Does anybody have the dimensions of the gas pedal installation template? We don't have one in the kit and are trying to figure out if it is even necessary. Can we just mount the pedal in the right place and be OK or is the template really important?
I can give you the dimensions but it's only there to get the hole spacing correct. I didn't use it. I just put the pedal where I wanted it drilled the holes and moved on. You sure your template wasn't in the box with all the aluminum?
Keith
1 - 3 of 3 Posts
