airman,
You can increase the illumination of the LED's by driving more current through them. Here's how:
Try using a smaller value resistor and see if that helps give you more illumination.
Down fall to this solution is the more current, the more you will shorten the life span of the lamp. However, LED's do last much longer than standard incondescent lamps.
Just make sure you dont over-drive the LED or they will burn up.
Colored LED's also dont illuminate as much as white but they sure look cool!
Decrease the resistor value in small increments.
Best bet is to get a variable resistor and find a value that works best. Then measure the value and purchase resistors closest to the one you have selected.
Make sure you have the LED's pointing at the area you want to illuminate. Keep in mind the angle of viewing is much smaller in LED's than on incandescent lamps. You may have luck by positioning them better along the light pipes on the back of the gauge.
Good luck,
Ed
FFR1997K
