1 - 3 of 3 Posts
I am using a Windsor mortor with Edelbrock Mass Flow EFI. I plan on mounting a fuel vapor canister in the rear near the gas tank. Does the casister need to connect anywhere else other than to the gas tank vent?
To a vacuum source on the intake maniford.
In the vacuum source line you will need a vapor canister check valve solenoid.
Tom:
The other end of the check valve solenoid goes to the bent pipe on the throttle body.
I turned the pipe 180* so it now faces the firewall and the tubing is a little less conspicuous that way.
I mounted my vapor canister to the battery box in the trunk( FFMetal)and routed the vacuum line through the tranny tunnel and then to the solenoid.
HTH,
Paul M.
1 - 3 of 3 Posts
