1 - 1 of 1 Posts
-For Any Others Concerned-
Replaced the Factory Five Supplied Fuel tank with a Boyd Aluminum Welded Tank. I did not feel comfortable with the original tank due to the fuel sending unit being below the top of the tank and sealed with a rubber flat ring gasket. The Boyd tank was a easy swap and there is no fuel leak possible unless the inlet fuel hose comes loose which also is at the top of the tank.
1 - 1 of 1 Posts
