I don't want to use the stock mustang tank. What are the alternatives that won't bust the budget.
oldguy668 · Premium Member Joined Jan 28, 2002 · 12,146 Posts Discussion Starter · #1 · Feb 24, 2002 Only show this user I don't want to use the stock mustang tank. What are the alternatives that won't bust the budget.
oldguy668 · Premium Member Joined Jan 28, 2002 · 12,146 Posts Discussion Starter · #2 · Feb 25, 2002 Only show this user ttt
4-Harps · Registered Joined Jan 29, 2002 · 1,029 Posts #3 · Feb 25, 2002 Only show this user Do you mean you don't want to use the donor tank or don't want to use a Mustang tank? I bought a new Mustang tank from APE in Taunton, MA for around $110 (Can't remember exact will check if you'd like). Other than the Mustang tank you can go with a fuel cell but you're looking at some bucks there. What did you have in mind? ...Dave
Snakebit31 · Charter Member Joined Feb 1, 2002 · 2,612 Posts #4 · Feb 26, 2002 Only show this user I went with the JAZ fuel cell. 16 gallon with foam, $169.00 at Jegs. Mounting bracket is $19.99, needs slight modification, fits great.
J jmimac351 · Registered Joined Feb 26, 2002 · 482 Posts #5 · Feb 26, 2002 Only show this user Rob, I assume it is mounted in the trunk? Do you have a picture of the tank and the rear of the car? Jim
oldguy668 · Premium Member Joined Jan 28, 2002 · 12,146 Posts Discussion Starter · #6 · Feb 26, 2002 Only show this user Rob: Can you give us a pic or a part number?
