1 - 2 of 2 Posts
First, don't run the pump w/o fuel if it is avoidable. The fuel cools the pump. Without fuel the life of the pump will be reduced.
Your problem sounds like an ignition switch problem. Are you using the donor switch? If not, how did you wire the aftermarket ignition switch? The start terminal of the aftermarket ignition switch should have only one wire on it. It's white with a pink stripe.
1 - 2 of 2 Posts
