all parts have about 5 miles on them from just playing around with my new DFI setup, and are in perfect condition. the mass air meter is brand new and has not been used yet.
FMS 30# injectors $200
matching 80mm mass air meter. $140.00
holley systemax intake/ internal egr(new style). $525.00
75mm throttle body-$120.00
comp cams xe282 part number CCA-35-522-8 ---$225.00
Cam Style Hydraulic roller tappet
Basic Operating RPM Range 2,600-6,500 RPM
Intake Duration 050 in Lift 232
Exhaust Duration 050 in Lift 240
Advertised Intake Duration 282
Advertised Exhaust Duration 290
Intake Valve Lift with Factory Rocker Arm Ratio 0.565
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.574
Lobe Separation (degrees) 112 degrees
Intrax springs 2in drop. (about 200 miles on these) -$125.00
