Hello
I have been trying to figure out this problem for months. I cant seem to get the GTM to start.
When I try to start the engine, it fires and dies. I took the fuel injectors out and tried starting it and the would pulse twice and then stop. I have spark and my fuel rail pressure is adequate. After the one fire the engine will just crank.
Background on the car
06 GTO LS2 engine
LS1/LS2 harness that I chopped and put back together.
98 pcm
the engine has a 24t reluctor
I have done everything that someone would do for an ls1 to ls2 swap.
When I run my OBDii, no codes appear. Not even expected codes. It does however show what my sensors read my no codes.
I double checked to make sure my injectors were all wired right.
I sent this computer to FFR twice to have the VATS removed so I am confident they have had it removed. :glare:
Tried new crank sensor and when I crank I get normal rpm on my OBDii reader.
Please help and ask any questions I will provide all the info.
06 GTO LS2 engine
98 pcm
