1 - 2 of 2 Posts
Kit is 97% done, running yesterday to check on all the odds and ends and found the rebuilt alternator I installed a few months ago suspect. At idle the red light was on and as the revs went up the light went out, at about 2500 the light came on again. Today it didn't go out at all. Other than the alt what else could it be? Thanks, Bob
Only two things besides the alternator I can think to check. The first are the two wiring connections at the alternator. Also, using an Ohm meter check that the alternator housing is grounded to the engine block and that the block is grounded to the chassis. If you painted the alternator or the engine you could have inadvertently removed the ground path for the alternator.
1 - 2 of 2 Posts
