Are you not willing to pay $150 for a dial in-lb torque wrench?
Want a quick and dirty way to determine those subtle measurements?
Well, behold, LuisO's patented and SAE approved in-lb dial torque wrench:
I needed to measure this for my IRS rebuild (pinion bearing preload) and put this artifact together. The wrench measures 4.5" , the fish scale, while not exact, I don't think will have more than a 2 lb. error (don't believe me, it says it right there, "Deluxe")
So if you need 10-28 in-lb of torque, let's see:
10 / 4.5 = 2.22
28 / 4.5 = 6.22
So when you pull on the wrench using the scale handle, when it measures aprox 2 1/4 lb, you are exerting 10 in-lb of torque. The same when you read 6 1/4 lb, 28 in-lb torque.
So, aim for the middle ground between 2 1/4 and 6 1/4 which is 4 1/4, so even with this not very exact measurement, you'd be within spec.
Yeah, go ahead and call me crazy.
[ May 06, 2003, 11:55 AM: Message edited by: LuisO ]
