The wheel openings were tightened up on the Mk4 so depending on which spindles you have putting 275s on the front ranges from nearly impossible to just barely. Your best shot will be with FFR, Fox or '94-95 spindles along with 1 degree or more of negative camber. You definitely need to trim back the front wheel opening returns.
I had a set of 245/45/17 on the front and sold them, drove the car had no issues would like to put 275 on the front. this was a complete kit build so I used the FF5 spindles with 6 pistons calipers
Do it. Yes, 275s need some care to make them work on a MkIV. I have always wondered about why FFR did that. Anyway, if there is a bit of work required, I think it will be worth it.
These are NITTO 555 in 255X40X17" ride height currently about 3-3/4" or a little less on the front with stock FFR wheels. They were a simple jack the car up & bolt on the wheels. The car was Auto-X'd at this height without any rubbing on the frame or body. This is normally as big & you can go without some modification to the MK-IV.
The ride height is a bit low due to the spring settling, something else you need to think about with a fresh car. Am currently raising the height as part of my annual maintenance routine.
Thing you need to watch out for is you can't buy the tire based on 255 or 275. Even with the same number 275 vs 275 the physical measurement of the tire can be quite different.
If you want 275's up front also ask for a brand & tire within brank that someone here is using in that size to see how the tire actually fits..
In another brand of tires on a different car my 255 Yokohama 100's had the same tread width as a Goodyear 275.
You cant buy extreme performance, that comes from practice, seat time. These cars will stay on road just fine, the problem is the operators spend too much time on the go fast pedal when they should have been on the brakes sooner coming into a turn.
You can over drive any car into a turn, a Factory Five can go way too fast into a turn no matter what tires you have you will crash. This is where practice, AutoX or track days come into play. Go out and wipe out find out where the edge of you car and your skills lie.
My word of caution without proper respect and skills you will wipe out even on the best racing tires. Unfortunately you will be going wayyy too fast and they give you no warning they just go. Where as good street tires begin to squeal when they are approaching edge.
In addition to added cornering power if tuned properly, the 275s help a lot w/ the usual FFR too much front brake problem. Mine is a MkII but I have never run less than 275s since 2007. For autocross rubber in 2015 I ran 295s on 9 in wheels first and then on 10.5 wheels for the last half. In 2016 I ran 315s on 10.5s on all 4 corners
Looking for the paint code for the anthrocite color on the Trigo pin drive wheels that I purchased with kit from F5.
Called Trigo and all they would say was spray canned on, (what ?)
Ken at Street Rod paint is doing the painting. Guess I could bring a wheel to him to match, can that be done...
I know that this is a long shot (and it really belongs in the classified section) but I am looking for a small bracket that attaches to a Fox Mustang pedal box. This bracket holds the clutch safety switch. The salvage yards around here don't want to deal with a small part like this. See the...
Happy(?) 10th anniversary to me and my FFR!
Exactly a decade ago (Thanksgiving eve), the truck pulled up to my house and dropped off my Mark 3.1 Roadster kit.
10 years later, and it still isn't finished. 😔
I haven't even touched it in over 4 years (until today)!
The 1st few years, I enjoyed...
