Anyone know the correct size/length of the bolts? If not, I will take bracket to Lowe's and figure it out. I assume grade 8 would be necessary. Thanks,
just another builder
gettem from breeze...the nuts are crush nuts and the bolts are flanged...they bare not cheap...I would be wary of a lowes low dollar solution on this application...but that's me
65 FANGS
My 94-04 spindles from dbrus came with 16mm (5/8") x 2 5/8" x 13 treads grade 10.9 with washer under bolt head and flange nut.
The manual says to use the donor bolts - so I would assume they're availalbe from your local Ford dealer too.
Thanks guys, just ordered from Breeze.
