1 - 2 of 2 Posts
Was looking to make front brake ducts positioned in the outer corner of the radiator opening, then turning 90 degrees to pass through the reinforcing plate for the hood before using high temp flexible ducting.... any thoughts or prior attempts..??
With thanks
Chris
Discussion Starter · #2 ·
ABS printed 90 degree inlet ducts, with a two piece 3mm AL angle bracket... similar to what I ended up doing on my open wheeler.. will no doubt be of some assistance, if not as good as a fully ducted solution.
Automotive tire Helmet Wood Tool Automotive lighting
Automotive tire Hood Automotive fuel system Motor vehicle Automotive lighting
Hood Automotive tire Automotive lighting Tire Sports equipment
  • Like
Reactions: JimS
1 - 2 of 2 Posts
