Two boxes of left over parts, mostly FFR 'complete kit' parts, that I didn't use. All new, some were mounted but taken off and not used.
I'm in South Bay (southern Calif., Palos Verdes/San Pedro), so come by and take them all. I hate to just throw them away.
If you need just a single part or 2, and you are not in the area, we can work out some sort of shipping.
Best way to get in touch is my email [email protected], 'cause I usually miss that little notification flag at the top.
Here's a partial list (from the top of my head)...
throttle pedal
Headlight bulbs, Wagener
hood pin set
fan belt (Gates K060620)
idler pulley
radiator cooling fan mounts (aluminum straps, and the push thru plastic pins)
battery hold down kit
conical air filter Gone
clutch cable, bulkhead mount, pedal cams, and some hardware Gone
fender bullet mirror Gone
MSD 6-AL ignition Gone
oil filter relocate kit Gone
fuel tank pickup (non FI I believe) Gone
fuel filter Gone
misc battery cables, grounding cables Gone
the flat fender side louvers (and angles) Gone
roll bar trim rings Gone
remote brake reservoir Gone
ignition key switch and keys Gone
dash toggle switches (4 or 5 of them I think) Gone
coolant T filler neck Gone
side pipe hangers Gone
flashers Gone
dash indicator lights (red, blue, 2x green) Gone
Vintage Air manual heater valve with control (knob, cable, switch) Gone
Vintage Air defroster vents and trims) Gone
speedometer pickup (with 2 gear ratios) Gone
quick-jack bumpers, front and rear, raw Gone
starter solenoid (panel/firewall mount) Gone
I've got quite a bit of aluminum sheet, angle, bar stock left over as well. You'll have to pick through that.
Also a fair amount of fasteners as well.
I think that's about it.
throttle pedal
hood pin set
idler pulley
fuel filter Gone
flashers Gone
