1 - 3 of 3 Posts
Fox Lake built 418"
assembled shortblock, forged crank, H-beam rods, Ross pistons ( .030" over, flat top, 12.5:1 comp) balanced to 28oz, with main studs. New style Stage 3 ported Trick Flow Hi Port heads, flow 327/[email protected] lift. Custom solid roller cam .670/.641 lift and 266/276' of duration, degreed. Harland Sharp rockers 1.6 street heat off set. Comp Cams solid lifters. Trick Flow pushrods. Billet timing set. New timing cover. Canton drag race oil pan kit, blueprinted HV-oil pump, ARP oil pump drive shaft. Ported Super Victor intake manifold. Pro Systems HP1000 based carb, flows "like a dominator". ARP bolts throughout. Fel-Pro gaskets.
Other than the shortblock, this engine has never been assembled. Everything is brand new, never fired. I have decide to run NMRA Real Street instead of Wild Street. Both Ron at Fox Lake and Patrick at Pro Systems agree this motor will easily make 650hp before nitrous. I do not want to part this motor.
I have 11 grand in receipts. Asking $7,500.oo obo.
How deep into the 9's do you want to go? If interested call (614)755-4885 or email [email protected]
Josh
1 - 3 of 3 Posts
