Status
Not open for further replies.
1 - 16 of 16 Posts
Professional Internet Browser
There is a samll run of manuals from last srping that have a misprinted gas cap driliing pattern. The printer resized it without permission. When I used it to drill my cap, it ruined the cap. FFR is giving me a replacement, but I just wanted to warn all of you incase you had not reached this step. The pattern should be the same size as the flange on the cap bottom, not a little smaller as mine was.
Thanks for the heads-up Aaron. I made a note to be sure and check it.
TEC
I figured out the size difference before I drilled, guess I was lucky eh!
That is a long running error. Mine was like that and my manual arrived in Dec.2000. I noticed the size problem before drilling any holes.
FFR Driver
Ditto. I just laid it on the cap base saw it was off and punched the holes inward prior to drilling. And do make sure to take the assy apart so you don't ruin the cap when drilling. :eek:
Thanks for the heads up!
Super Moderator
I wanted six, equally spaced holes - so I made this diagram. NOTE This was to scale for me, but might not be for you due to differences in printers, etc - but, you should at least be able to use the lines to get the proper spacing of the holes (if you want 6 bolts)
I posted about this back in July and all of the responses I got said that nobody was aware of any problems with the templates.
All of my templates are to small. tail lights, head lights, gas cap etc...
measure twice and cut once
Becareful
Cody
Alot of my templates are small...I ignored them and use the written dimensions...the ones that I have anyway...!
Not only are the templates too small, the indents in the molded bodies themselves no longer correspond to where the screw holes go for things like the tail lights, tag light, etc. Check everything before you drill.
Leonard
1 - 16 of 16 Posts
Status
