I am planning to use motorsport rear springs for my 4link in place of cutting the factory springs. Will the ride height be the rough equivalent?
Tony W.
You can set the ride height with either. There are other issues to consider. The quad shocks will help. Some guys have wheel hop, mine never did.
I don't have an FMS catalog but...I recommend stock springs.I am assuming that an FMS spring is probably a bit stiffer but I may be wrong there.My car came w/ cut springs which were too short to allow ride height options.I got stock GT springs from someone on ebay.The top coil of the springs is collapsed on stock springs which makes for a mismatch w/ the spiral on the FFR.I used a torch to expand the top coil so it's curve nearly matches the rest of the spring.This setup worked fine.
