427 Ford Big Block FE ENGINE
Price: $5,600
Location: Williamson, NY (between Rochester and Syracuse)
Condition: Excllent
For sale is a great 427 ci ( also called 7 liter ) Ford Engine complete as described below. This would be great for your Shelby Cobra, old Ford, Galaxy, Fairlane, Mustang, or any cool hot rod cusom project.
BLOCK
Ford 427 Top Oiler Block date code C8AE-6059-B (this is a 1968 Service/Boat Block because it is cast as a side oiler, but it is drilled as a top oiler)
0.030 bore.
Screw In Freeze Plugs
Block Square Decked
4-bolt Crossbolt mains on # 2, 3 and 4. Main caps, main bolts and cross bolts & spacers installed and included.
The numbers on the block include a 66-427 casting on the back like all 427 motors.
Melling High Pressure Oil Pump
Cam is E9630, Valve Springs 46622, PR78 push rods, CB760 P-10 Rod bearings, KB199 Keith Black pistons.
Low rise heads C7JE 8090A –Competition Valve Job and Guides machined for Teflon valve stem seals.
Crank is 3U
Stock Oil pan
New water pump
Aluminum ‘Cobra 427’ finned Valve covers.
Comes with two aluminum intake manifolds, a Edelbrock Performer and the Wieand that is on it. I also have the distributor with a Petronix kit for it.
Please contact me with any questions. It is located in Williamson, NY, which is between Rochester and Syracuse.
Jason
Price: $5,600
Condition: Excllent
BLOCK
0.030 bore.
Block Square Decked
Crank is 3U
Stock Oil pan
New water pump
Jason
