1 - 3 of 3 Posts
I'm on a roll today getting some great advice on the Forum so I thought I'd ask one more niggling question!
I just installed my Flaming River rack per the instructions, spot drilled under the set screws and used red loctite. The instructions said to drill all 7 places. That would mean to drill the spline shaft too. It didn't make sense as there is a relief groove turned on the spline, I tried it anyway, but that sucker is hard! So I just tightened the last set screw and called it a day. Any words of wisdom here before I call the factory?
Thanks again.
Tom
· FFCobra Fanatic
I did the same and haven't had a problem in over an year and about 6000 miles. I still compulsively check the tightness but haven't had the slightest bit of losening.
· Senior Charter Member
Tom,
Much as you did, I drilled all but the shaft with the groove. Much as you did, I used loctite.
However, in addition to all else, I shortened the shaft between the u-joints to eliminate any possible binding.
All the best,
1 - 3 of 3 Posts
