Decided to secure my floor mats in a better way than what I originally tried.
For those following along, I bought some Eagle Claw hooks that were supposed to grip the underlying carpet. The bottom of the hooks are sharp and barbed and meant to pierce through the carpet and grab on. You release the mats by unscrewing a cap on the topside of the mat that engages with the barbed claw underneath.
Well, I discovered that the kit carpet plus the sound deadener is not thick enough for the barbs to pierce through. And while driving my DS mat tends to get bunched up in the front of the footbox by the pedals...Not safe...
I decided to secure the mats by putting a couple of 1/4"-20 socket head screws and fender washers through the mat and into the front side of the 2" frame just after the floor drops. First I punched a hole on either side of the mat after marking with a sharpie, "cauterizing" the edges with a soldering iron to prevent fraying. Then transferred the position to the front side of the frame.
This is where it gets fun. If you've ever tried to drill and tap a hole blindly on the front side of the frame while doing a crazy yoga plank in a hot 85* garage, you're missing out. Also don't put the holes too far to the edge of the mat as the inside bend of the footbox prevents you from getting a drill into that location. I ended up using a right angle attachment and got it to work.
At the end of the night, I was able to get the PS mat done after an hour with lots of swearing and sweating. I'm leaving the DS for another night. In the end, no one will likely ever notice, but isn't that the point?
"Can't see the line, can you Russ?"
-CW Griswold
-CW Griswold
