661 - 677 of 677 Posts
My wife and I just had a baby yesterday, so I feel like my wings will be clipped for a while. Now if I can only figure out a way to install a rear facing car seat in the cobra ...
Congrats man! That's so exciting! Get some baby earplugs and get that seat in! Gotta start them young
  • Like
Reactions: egchewy
Congratulations!!!!!
Lol I squeezed my youngest in the backseat of my Mustang to bring him home lol. My wife still complaims about that!
Congrats... Does F5 have an adaption for a baby seat?
Discussion Starter #664
Someone wanted to help me assemble my wind wings
362430
Very Cool.;)
congratulations! Enjoy every minute, they grow up fast.
Discussion Starter #668
Working on windshield wings and sun visors. Decided to not use the kit provided screws for the visors to prevent windshield cracking and went with the square nut option through the top windshield channel. I used #6-32 screws/ nuts and works great. Had to cut the screws to around 7mm to prevent them from hitting the bottom of the channel.
362461
362462
362463
362464
  • Like
Reactions: jhargrove
Got my custom radiator tubes back. Shout out to tubular techniques in Hilliard Ohio for a nice mandrel bend job. Wired up starter, temp senders, oil pressure sender, alternator mega fuse View attachment 359354 View attachment 359355 , fitech fuel pump and fan ground wires View attachment 359352 View attachment 359353 . Installed upper radiator tube. Need to get a couple more hose clamps before installing lower tube.
several more items off my punch list
-moved + battery cable to the inside of the PS 4" tube. it was formerly running on the outside, which would have put it directly under my J pipe
-started drilling/tapping the outside of my PS frame for my flex SS braided fuel line. that is until I snapped my tap. I have line separators that have a slightly longer bolt that goes through the middle that will tap into my frame. I think i'm going to rivet in a few insulated clips for insurance along the path of my fuel and return lines.
-had to mess w/ my throttel linkage a bit. gas pedal was a bit too high for my liking. in the process discovered that my tension pin on one of the arms wasn't actually all the way in. glad i found out now.
-started mocking up a template for a lower radiator hose. my stupid pre 1969 engine has the water pump coolant inlet on the PS instead of the DS. All aftermarket solid tubes are for the DS inlet. I used some spare brake line, heater hose insulation, to mock up a shape. seems to be about right. i'll find a custom muffler shop who can mandrel bend me some 1 1/2" tubing and put in a flair/raised bead for a hose clamp.
-attached my shifter and Breeze knob and did the obligatory pretend driving/shifting, making vroom vroom sounds in my head.
-attached new delco engine temp sensor for my fitech. read that the one that comes w/ the unit reads consistently 20* too cool.
What type of shop did you have make your lower radiator tube?
Discussion Starter #671
I initially called a muffler shop thinking they might be able to bend the tube for me. They directed me to Tubular Techiques as we needed a mandrel bent tube and the muffler shop didn't have the right equipment. I'm still convinced that if you find the right muffler shop or hot rod shop, they would have the equipment to do the bending. I made a template out of an extra piece of hard brake line wrapped in water heater pipe insulation (left over from my body buck padding) to get the correct OD, and gave the tube shop my template. They did a bead roll on both ends for a hose clamp as well. Cost was maybe just under the Boig or Breeze solid tube pricing.
Discussion Starter #672
Mini milestones... picking my son up from track practice
362639
Discussion Starter #673
Drummer Mike shields installed, at least on DS. It's a shame he's not making them anymore. Beautiful polish.
362660
I think I got one of his last ones before he stopped production.
Drummer Mike shields installed, at least on DS. It's a shame he's not making them anymore. Beautiful polish. View attachment 362660 I think I got one of his last ones before he stopped production.
OMG I am so happy I got mine. They look fantastic Chewy! I am going to wait myself. Until everything is done. I want to wait to add some of these items like heat shields and wheel knock offs until the end.
Discussion Starter #675
Thanks for the heads up about Mike going to his winter home. I probably wouldn't have ordered my shields and likely would have missed out if you didn't alert me of the fact.
I am very happy that you got some. No problem. They are very very well done..
Discussion Starter #677
Ordered a rear view mirror bracket from darkwater customs 2 months ago (still waiting) and got tired of driving without a proper mirror, so i fabricated my own from some angled aluminum i had laying around.
362678
