hope I can get mine to fit easier than yours.I ended up cutting the trunk apart, re-contouring it and glassing it back together
gotcha. i'll be very conservative w/ the trim as to avoid making more work for you down the road.Rich’s car is a Mk3, as is my own and at least a half dozen others that I’ve done and none needed to be recontoured.
Eugene, if you trim the lower edge of the lid the whole thing will drop down to more closely match the body. Once that is done you’ll use the inner and outer nuts/spacers on the threaded rod to move the lower balance in or out as necessary to meet the lower edge of the lid.
