1 - 1 of 1 Posts
Got home yesterday from a four day trip, it was beautiful on the Cape. I know I made a promise to climb up on my ladder and continue to paint, but Miss Caroline was in the garage whinning to go out on the road. So guess what I did.She was running great down by the beaches when it started, engine was dying under the light throttle ,give it a little gas and it would die. As this is occurring I'm recalling all the post I read on engine problems and symptoms, I'm thinking ignition box , but the engine would come back, next thought was fuel filter problem
so as I'm self diagnosing we manage to get her home.After letting the car sit for a little bit
(also had to lean the ladder on the house just to make it look like I wasn't slacking off) I turned on the baterry switch and the fuel pump
, nothing from the fuel pump, check the circuit breakers and they were fine. Next I suspected a grounding issue, sure enough that was the cause.
AGAIN PAST POST FROM THIS FORUM SAVE THE DAY
Thanks Guys
1 - 1 of 1 Posts
