1 - 11 of 11 Posts
I had my car on the Dyno today at DEZ Racing in Seekonk, MA. I was going to try and post the sheet but my email is down at the moment, so here are the nuts and bolts of the session. The engine is a 351W stroked to 393 ci with a kit from speed-o-motive including Probe Forged SRS pistons, AFR185 heads, Static Comp ratio is 10.1/1, comp cams XE266HR cam with FMS linkbar roller lifters and Harland Sharp 1.6 roller rockers, Crane Street/Strip Distributor, Crane HI-6R ignition, Blaster II coil, Holley 770 Street avenger Carb, Weind Stealth intake.
HP at the rear wheels was 355.1 @ 5400 RPM, Torque was 400.1ft-lbs @ 3300 RPM. The torque curve was almost flat, from 2100 RPM to 5400 RPM I had over 350 ft-lbs of torque. AF ratio was not bad, a little rich. Jetted the secondarys down one which helped, around 13/1. Had a dip in the AF ratio from 3500 rpm to 5000 rpm, it was at a low spot @ 4500 rpm with 10/1 AF ratio, but still acceptable. I am happy with the motor and it sounds great at full song. I will post dyno pull when I get a chance.
Sean
http://img.photobucket.com/albums/v684/Crook038/dynorun.jpg
BAM! Gettin me excited and motivated to get mine on the dyno. Great numbers and looking forward to seeing the the sheet.
Administrator
All you gotta do to post an image that is on the net is put
directly after it.
Wow, big pic! Nice numbers too!
CNGreen
Crook - Looks vrey good. Anybody remember what the rule of thumb is for loss thru drivetrain? Was it 17%? If it was 355 at rear wheels, what would it be at flywheel? Same Q for torque?
What Roadster Jeff said! Wow what a torque "curve". That's as good as I have ever seen. Super.......
1 - 11 of 11 Posts
