Hi Folks-
footbox and 3/4" strut
So I'm about to mount a starter relay on the firewall, kind of underneath the 2x2 the firewall mounts to. I'm looking at what John? did at my427sc.com, but all of a sudden the firewall starts looking a LOT different. It appears that in my kit (it's a Mark2) there are "struts" that aren't there in a couple of the other build sites I see out there. These struts angle forward and down along the engine side of the pass and driver's footboxes, and come really close to the scattershield flange. I'm talking about the 3/4" 'diaganal' strut that's right above the tire in the attached pic.
This does not inherently present a problem, it's just got me curious and wondering if I'm missing some aluminum
I can't find enough pictures online to correlate whether this is a difference between the Mark1 and Mark2 kits, wondering if anyone knows.
I'm looking for a clean place to put the starter relay, but the way my aluminum is set up, I'll be mounting it to the "engine side" of the vertical aluminum that mounts at the front of the transmission tunnel, leaving mounting screws poking through right above the xmission tunnel in the cockpit.
So after my rambling, I guess this is what I want to know:
Are the mark1 and mark2 kits different in that the mark 2 kits have 3/4" struts that connect the trans tunnel to the 4" tubes in the engine compartment, and if not, how do I square away the firewall aluminum?
If the former is true, and those 3/4" struts are to remain visible on the firewall and on the engine side of the footboxes, anyone got a nice, clean, accessible place to mount the relay?
Thanks folks.
c
Thanks folks.
c
