Installing the pedal and have interference at top with what Helms calls the clutch pedal swith and Clutch switch. It is located top right inside pedal box, attached to the plastic clutch gear assembly. When the clutch is depressed, a plunger pops up. It has a pigtail with a small 2-prong female connector attached to it. Finishline mentioned a cruise control switch that might interfer; is this it? I don't need it? Thanks.
