1 - 2 of 2 Posts
i know this has been discussed but the way i have my headlights wired when i flip the toggle for hi beams the low beams remain on. is this a problem (having both hi and low beams on at same time). also just put on the elephant ears with help from oldguy668's posts and i notice that my front disc brakes pad are only touching the rotor in two spots. i have noticed that on my rides the brakes dont seem to be working well any suggestions. i changed to 4 wheel discs but am using the original donor master cylinder
1. Are you using the donor harness? If so, how
are the headlights wired? Are both beams
being powered by the fusible link which
originally powered only one beam at a time?
If so, I'd be concerned that the fusible
link will eventually fail.
2. The brake pad wear thing is normal. the pads will wear down until they contact the rotor all the way across. Braking will improve considerably as that happens.
1 - 2 of 2 Posts
