Ok here is the set-up..
Fuel safe tank
Carb
Original Ford fuel pick up unit modified with pump removed and pick up added. Big tube out of pick-up goes to carb the small one remained but is capped
One of those gas caps that you do not need to remove (has the flapper door built in to put gas nozzle into..
Here is the issue.. Stop to fill up with gas. First thing I do is open the trap door in the gas cap to releave trapped air. woosh it is out!
I start to fill her up and everyone is looking at the car... Whoha! gas is spraying out everywhere.. At about 5 gallon mark it seems to build up pressure in the tank and come out the fill area! What a mess. Good thing I am not painted yet...
Any ideas.. Can I use the small line on the pick-up as a vent...
thanks
Smoking joe!
Fuel safe tank
Carb
thanks
Smoking joe!
