The holes drilled in the body are 1/2" and the wheel box shaft tube measures 5/8"...What is the best way to enlarge the holes? If I drill it the fiberglass could splinter...I guess I could file it larger. Has anyone had this problem before? Thanks for any help....
Thanks, Wade, looks like you had the same situation....BTW, your build site is terrific...
I used a rotory bit in a dremmel then finished up with a rat tail file. Take your time as its a little tricky getting the right angle so the wiper boxes sit correctlly. Since just starting may want to consider repalceing the rubber angled peices for under the cowl for pvc pipe cut on an angle. This helped a lot in keeping everything aligned when tight.
