21 - 27 of 27 Posts
Choosing what to buy
Discussion Starter #22 (Edited)
Jan 15, 2021 UPDATE ON PARTS LEFT:
  • Ford 429 Mounts
PLEASE, YOU DO NOT NEED TO ASK ME FOR PRICES SINCE I AM GIVING THESE PARTS AWAY. THEY CAME WITH THE KIT AND THEY NEED A GOOD HOME. YOU MUST ARRANGE FOR SHIPPING HOWEVER.
Let me know if anyone needs any of these.
Hello I completed my FFR MkIV Roadster and tried to get the originality to the comp 427 as close as I could. As a result, I have a BUNCH of extra parts:
  • Stainless Steel side pipes (Too loud and they discolor in a flash... need polish to go back to clear). Went for Quiet Pipes
  • Radiator (Never touched)... Installed Fluidyne
  • Radiator Flex Hose
  • Radiator Expansion Tank
  • Ford 429 Mounts (Sent by mistake)
  • Front Spindles (5 lug). Mistake. I have knock-offs
  • Rear lights ... Went for square
  • Cobra Oval Air Filter from Finishline (Won't fit with side oiler)
  • Alternator (Got a vintage style)
  • Dash pre-punched ... made my own
  • Dash padding with foam
  • Trans Tunnel fake support rods
  • Shifter and knob ... used original
  • Pedal plates
  • Complete carpeting kit ... Used Bentley wool
  • Stainless Radiator opening Bumper Ring
  • Trans Speedo sender
  • Top-Loader Trans Output shaft U-joint adapter. Went for TKO
  • 500lbs coil-over springs (2)
  • Brake Fluid Reservoir
  • Clutch Cable Kit
  • Throttle Cable Kit
  • Oil Filter Remote Adapter
PLEASE, YOU DO NOT NEED TO ASK ME FOR PRICES SINCE, OTHER THAN THE SIDEPIPES, AIR CLEANER AND RADIATOR, I AM GIVING THESE PARTS AWAY. THEY CAME WITH THE KIT AND THEY NEED A GOOD HOME. YOU MUST ARRANGE FOR SHIPPING HOWEVER.
I assure that the Radiator Expansion Tank is gone. If not I will take it.
Interested in side pipes if still available. sent you a pm
It might be easier if you go back and edit the original post and delete all of the things that are sold. It's hard to go through all of the comments to figure out whats sold or not.
Just a suggestion.
Discussion Starter #27
Just a suggestion.
DONE
21 - 27 of 27 Posts
