Let me attach so you'all can see the discoloration. Supposedly it polishes back to Chrome look but immediately re-tints after the engine starts...any pics off SS sidepipes and how much?
thanks
I have no idea who makes it. It is the one that comes with the complete kit. I also have all the accessories for it as I listed.I may be interested in the radiator. Which version is it? AFCO or the New Unbranded FFR Radiator? Cost? I can pick up locally if it's an option.
I take the following if they are still available.Hello I completed my FFR MkIV Roadster and tried to get the originality to the comp 427 as close as I could. As a result, I have a BUNCH of extra parts:
PLEASE, YOU DO NOT NEED TO ASK ME FOR PRICES SINCE, OTHER THAN THE SIDEPIPES, AIR CLEANER AND RADIATOR, I AM GIVING THESE PARTS AWAY. THEY CAME WITH THE KIT AND THEY NEED A GOOD HOME. YOU MUST ARRANGE FOR SHIPPING HOWEVER.
- Stainless Steel side pipes (Too loud and they discolor in a flash... need polish to go back to clear). Went for Quiet Pipes
- Radiator (Never touched)... Installed Fluidyne
- Radiator Flex Hose
- Radiator Expansion Tank
- Ford 429 Mounts (Sent by mistake)
- Front Spindles (5 lug). Mistake. I have knock-offs
- Rear lights ... Went for square
- Cobra Oval Air Filter from Finishline (Won't fit with side oiler)
- Alternator (Got a vintage style)
- Dash pre-punched ... made my own
- Dash padding with foam
- Trans Tunnel fake support rods
- Shifter and knob ... used original
- Pedal plates
- Complete carpeting kit ... Used Bentley wool
- Stainless Radiator opening Bumper Ring
- Trans Speedo sender
- Top-Loader Trans Output shaft U-joint adapter. Went for TKO
- 500lbs coil-over springs (2)
- Brake Fluid Reservoir
- Clutch Cable Kit
- Throttle Cable Kit
- Oil Filter Remote Adapter
Let me know if anyone needs any of these.
PM me and we can arrange.I take the following if they are still available.
Radiator expansion tank
Alternator
Pedal plates
Brakes Fluid Reservoir
Clutch cable kit
Throttle cable kit
Thanks.
PM me and we can arrange shippingI will take the shifter and knob.
Thank you
Radiator is spoken-forI take the following if they are still available.
Alternator
Pedal plates
Clutch cable kit
Throttle cable kit
Thanks.
Which part number did you go with from Fluidyne?
PM sentPM me and we can arrange shipping
Alternator is OK
Pedal Plates are gone
Reservoir OK
Cables OK
PM me for shipping coordination.
I’d like the dash and pad if still available.Hello I completed my FFR MkIV Roadster and tried to get the originality to the comp 427 as close as I could. As a result, I have a BUNCH of extra parts:
- Pedal plates
- Clutch Cable Kit
It is. PM me.I’d like the dash and pad if still available.
