I want to use the rotary function of the FFR light switch to turn on courtesy lights.
Does anyone have a wiring diagram of this switch handy or knowledge of the switch operation?
If you are using the AAW or other aftermarket harness, the courtesy light circuit controls the ground side. Wire the courtesy lights to an always on hot source, and run the ground to the switch. I can't remember which terminal it is, but someone with a diagram will soon chime in. John
This what you need?
