Is the FF headlight switch (#12354) a traditional 2-pull (off-parking-headlights), or a 3-pull(off-parking-low beams-high beams) switch?
It is the traditional 2-pull. Off-parking-headlight.
It also has a function for dome/courtesy lights. Using this function the case of the switch has to be grounded seperately. The courtesy light function switches the ground wire of the lights, not the power. Just keep this in mind when you wire any courtesy lights. I just had to re-wire mine tonight because I grounded to the chassis and not the switch. You provide the power from the fuse box or seperately.
You will need a seperate switch for high beam.
Hope that helps.
Mike M.
Sorry to hijack, but how the heck is this thing wired? Am I missing a wiring diagram? I will do it this weekend.
Thanks Much!
Rich
If you have a AAW harness, the diagram is in the AAW kit.
Building Something
Painless also showes this same switch in thier 12 circut kit, go to painless.com and then to manuels and it has all info with pictures and wiring easy to follow.
Mike in NC
