I just received my Factory Five 17" Replica wheels, 17x9 fronts and 17x10.5 rears. In test fitting the fronts, I find that one of the wheels will not fit over the right side hub while the other wheel fits on this side OK. Is this a common issue with FF wheels?
Any recommendations? Return to FF, Sand ID of rim pilot hole to get clearance, or ?
Discussion Starter #4
Followup
The issue is with the ID of the wheel where it contacts the hub. The presence of the knock-off hub makes no difference. One of the supplied wheels fits fine. The one in question is a few thou undersize. Unfortunately, I do not have access to a lathe of sufficient size.
I guess I'll check with FF and see what they say.
I did not have any problem fitting my 17" Halibrands. I did have a bad lug nut though
