I've been asked to post this over here as well.
It's a MK4 Roadster with a metric ton of modifications.
  • Right Hand Drive
  • IRS, Torsen T2, 3.27 rear end.
  • Koni double adjustable coilovers.
  • Enlarged foot boxes.
  • VPM front and rear sway bars
  • Heat/sound insulation
  • ISIS electrics
  • T56 transmission
  • Flip top bonnet
  • Enlarged trunk
  • Engine shifted left and forward
  • Modular dash
  • Single, full width roll bar
  • Hydro electric power steering
  • Hydroboost brakes
  • ABS
  • Traction control
  • Champ Car removeable roll bars
  • Everything Breeze
  • Almost everything FFM
and eventually small block 427, 8 stack with EFI.
All the mods/fabrication was done by the travelling builder. You can't go wrong if you give him a call!
Let the games begin...
RHD drivers footbox
Straight through exhaust
Catalytic converter exhaust (about an hour to swap)
RHD Steering rack
Martin
Discussion Starter #2
Rear mounted AC unit
Champ roll bar mounting
Moved footbox tubing
Reinforced Wilwood pedal box
Assembled champ roll bars
Martin
Discussion Starter #3
Welded sway bar mounts
Hydroboost brakes
Symmetrical foot boxes
Trunk mounted battery box (and enlarged box)
Martin
Discussion Starter #4
EHPS and RHD steering
Shifted engine mounts
It's just been packed into a container and is on it's way to the UK tomorrow. Nearly here...
MUST.
KEEP.
CALM.
Martin
Discussion Starter #5
6 days to go...
forget calm. This is ridiculous. Tomorrow I'm going to assemble my new engine crane. I don't even have an engine yet!
Martin
Discussion Starter #7
cmon Martin
its almost there.
It should be in the country correct. Has it gone through customs yet?
Mark D
Not yet. It was supposed to arrive last Saturday, and clear customs today. It's now not due in until tomorrow, and no idea when it will clear customs.
At this rate, I can't be around to unload it, so I'll have to delay it for a week. :sad:
Martin
