Geek
Pin 86 is the relay actuation feed which is low current draw. Can be pretty small gage -16 or 18 would be fine. Pin 30 is the feed for the fan so should be more hefty - I would go with 12 or so. Same for pin 87.
Thanks! What about fuses? I am thinking 15 for the 86 pin and 20 or 30 for the 30. Any thoughts
Sent from my iPhone using Autoguide
section 8
I like the plug in circuit breakers on the fan side only because if the 20amp fuse pops you have no cooling. Where if the circuit or motor on the high amp said has an issue the breaker will "reset" and give a least a little fan operation . Just my .02 Bob
