I have a factory five mark 3 roadster that I built over the years 2005-2007. The car is registered in the state of Colorado as a kit. I have a clean title and the car has never been wrecked. Below is a listing of the features and specs of the car. Please ask questions and I can forward more picts of anything you want.
Kit Maker: Factory Five Racing MKIII
Frame: Black Powder Coated
Engine: 351W from Engine Factory (1974 block)
Power: 426 RWHP, 462 (ft-lbs) with N2O
Power: 520 HP at the flywheel (calculated)
Weight: 2306 pounds
Power/Weight: 4.4 lbs/hp
Carburetor: 800 cfm Edelbrock Thunder Series
Fuel Pump: Carter 4070 electric pump
Exhaust: Factory Five Racing 4-into-1 headers and side pipes, ceramic coated
Transmission: Tremec 5 speed, TKO600 (0.82 5th gear)
Rear: Ford 8.8, 3.73 gears
Suspension: 3-Link rear, Beilstein shocks and coil-overs front and rear
Brakes: Wilwood 6-piston front, 4-piston rear
Wheels: Team III, Front 17 x 8, Rear 17 x 10
Tires: Kumho, Front 245/45ZR17, Rear 315/35ZR17
Paint/Body: Lexus Spectra Mica Blue
Painted by Jeff (Batman) Miller (CA)
Dropped foot box
Chrome quick jacks
Autometer vintage gauges (reverse speedometer)
Aluminum battery box relocated to trunk
Cobra Earl's door liners with pockets
Cobra Earl's foot box vents
Hidden trunk hinges
Custom Tonneau cover by Auto Weave Upholstery (Denver)
Line lock
NHRA certified roll bar to 10.99 seconds (Hanksville Hot Rod here in Colorado). Welded to frame with hinged door bar
Faux front oil cooler (lines terminate just outside the wheel wells)
Drag race bracket from factory five to prevent axle wrap with hard launch
Drive line safety hoop
NHRA Scatter shield bell housing
Runs 11.2 seconds in ¼ mile at 121 MPH at altitude (Bandimere).
Miles driven over the years:
2006 117
2007 3603
2008 1931
2009 1554
2010 954
2011 244
2012 485
2013 153
2014 144
2015 0
2016 292
2017 37
2018 239
2019. 205
2020. 105
Total Miles 10069
As you can see the car just doesn't get driven much anymore. Time for someone else to enjoy!
Drives excellent and sounds great.
357805
357806
357807
357808
357810
357811
357812
357813
357814
357815
Discussion Starter #5
Sorry forgot to put the price. Asking $39500. There are a few more pictures in the above Craigslist ad.
